Hello! I'm just looking to learn how to program an IC or microprocessor for a realistic lighting system that I am wiring into a model airplane design.
Just need to know which type of processor to use and how to program it. It needs to be as lightweight as possible, and able to program specific types of strobe patterns for LED's. I looked at the 555 timer, but I'm not certain it can do the dual peaked flashes I need. For example: two quick pulses together, followed by a one sec delay. Such as.. blink blink...........blink blink....... Also, is there a way to use one small IC similar to the 555 to run two programs at the same time? Basically to describe what I need, it's just basic strobe, beacon, and solid lighting that all airplanes use. I know there are plenty of products that provide model aircraft lighting, however, they're not realistic enough, nor lightweight enough for my project. I've figured out how to use a tiny arduino to program lighting, but I'd really like to go smaller and lighter if possible. Thank you!!!
