Hello, I am trying to build a vumeter with LM 3915. The LM 3915 works pretty well with high volume but i mostly i listen music with headphone at low volume. At this case the only 2 led with light up.
I add an LM 386 as an amplifier and at full volume of that amplifier the led the light up as expected.
What i want to achieve is a kind of automatic process. When the volume is low the amplifier should make it high and opposite when is low the amplifier should normalize to not let leds stay only all on.
Also i hear some noise on headphone I try to add an 1N4007 diode but with that installed no audio passing through.
Thank you.
Thank you.
