Active Band Pass Filter (20Hz - 500Hz)
TelecoESP
Joined Jan 29, 2019
I am new here and it is my first thread, so... first of all: Hello everybody!!!
I have some questions (doubts) and I would like a second opinion. Thanks in advance!
1. Active Band Pass Filter
I would like to build an Active Band Pass Filter with f1 = 20Hz and f2 = 500Hz. I have selected Multi-Feedback topology instead of Voltage-Controlled Voltage Source due to the advantanges that we get in Multi-Feedback. Here is the schematic:
Figure 1. Active band Pass Filter (one stage)
I have been simulating the circuit in PSPICE and this is the frequency response curve:
Figure 2. Frequency response curve.
As we can see, f1 and f2 have dropped 3 dB of the mid-band gain. So the simulation and element values are right.
The questions are:
  • Which Op-Amp would you use? I have selected the IDEAL because I really don't know which amplifier is better for this project.
  • I would like to know if it is possible to have a gain equal to 1 (0 dB) with flat frequency response in the 20Hz - 500Hz range (as shown below) with just ONE STAGE:
Figure 3. Desired frequency response.
I have used "FilterPro" from TI to know the stages needed and I have obteined 5 stages. But I would like to discuss about this. I believe that 5 stages is excessive...
34,415
Not really.
Typically you can do no more than 3-poles in a single stage.
Why did you select a design which such a low passband gain?
Below is the LTspice simulation of an example 3-pole LP Sallen-Key type filter followed by a 3-pole HP filer, which gives a response similar to what you want.
It gives an 18dB/octave (60dB/decade) rolloff above and below the -3dB corners.
It is not necessarily optimized for your requirements.
Here and this are calculators for the 3-pole circuit values.
For those frequencies, just about any general purpose op amp will suffice (avoid the old 741 as it's rather noisy), but a low-noise one, such as the NE5532 would likely be good if you are concerned about noise.
LvW
Joined Jun 13, 2013
1,755
Yes - I fully agree with Crutschows recommendation. For a bandpass with such a small Q.value (Q=100/(500-20)= 0.21) it makes no sense to use the one-stage-bandpass MFB topology. The best solution is a highpass-lowpass combination.
Audioguru
Joined Dec 20, 2007
11,248
The multiple-feedback-bandpass-filter produces plenty of output at 10kHz even when its -3dB cutoff is 500Hz because it is much too simple with very gradual slopes.
LvW
Joined Jun 13, 2013
1,755
A second-order bandpass provides - far above the corner frequencies - a first order slope (20dB/dec).
The same can be achieved with a lowpass-highpass series combination - each of first order.
Using low- and highpass stages each of second order, gives a rising resp. falling slope of 40dB/dec.
isanapr
Joined Dec 2, 2020
Not really.
Hello, do you have the procedure to obtain the resistance and capacitance values for that particular frequency range (20-500Hz)?
