Reading Flash IC Memory by Desoldering the Chip
Status
Not open for further replies.
eswarkumarvarma
Joined Jan 25, 2019
9
Hii ,
I have desoldered a flash IC and put it in TNM programmer and tried to read and dump the firmware ,but i could not get any information .the output is shown below
what might be the reason for above output? i dont think firmware seems to be encrypted??
eswarkumarvarma
Joined Jan 25, 2019
9
Did you use hot air to remove it? Maybe it got hot enough to erase it?
Most likely the chip read-protection has been activated.
i have few doubts
1) when we power on a circuit board ,first control goes to bootloader and according to instructions written on the bootloader ,it will go to flash ic or some other parts right??.
2)If firmware is stored in flash ic and it is encrypted means ,where will the private key be stored and can we get that private key to break the security? please correct me if I'm wrong.
ericgibbs
Joined Jan 29, 2010
18,872
i have few doubts
2)If firmware is stored in flash ic and it is encrypted means ,where will the private key be stored and can we get that private key to break the security? please correct me if im wrong
Mod Note:E
Requesting guidance to Hack Security codes is not allowed.
Thread Closed.
Status
