I apologize in advance that I'm not very circuit-savvy, but I'm hoping someone here might be able to help me with a roadblock I've encountered in a pet project.
I'm designing an artificial window for a basement bedroom in my house. At 7 AM each day, LED lights behind the faux window will gradually dim up to full brightness, and stay on for a few hours. The window will have a sheen treatment over it to disperse the light and disguise the fact that there is nothing more than a concrete wall behind the curtain.
I've attached an amateurish sketch of my set-up, which consists of the following components:
1: LightenUp Model 212
When plugged into an outlet, this dimmer begins gradually dimming up the lights to full brightness over the course of 30 minutes.
http://windhovermfg.com/
2: HitLights 150 Watt Dimmable Magnetic LED Driver
To allow the LEDs to be dimmed very low without flickering.
https://www.amazon.com/HitLights-Dimmable-Driver-Magnetic-Transformer/dp/B00BU5UI2E
3: Ustellar Dimmable LED Strip Lights
https://www.amazon.com/Ustellar-Dimmable-Waterproof-Daylight-Lighting/dp/B078S1M78G
As may be expected, in my sketch, the black line is hot, white is neutral, and the green is the ground.
The set-up almost works perfectly. When powered, the lights dim up very evenly over the course of 30 minutes. However, when the 30-minute mark (full brightness) has been reached, something clicks and the lights turn off. A few seconds later, they turn on, but immediately click off again. This cycle repeats itself indefinitely. It is worth mentioning that the LightenUp component is not advertised as working with LEDs, but given that the actual dimming seems to be working fine, I'm not sure that this is the issue.
I would greatly appreciate any advice, preferably in laymen's terms. Thanks in advance!
