I was not sure where to post this as it uses non automotive electronics in an automotive application so if its in the wrong place please tell me and I will remove this and post it in the appropriate place. I have been working on a plan for a shift box for my track car with an auto trans for a few days now. I want to use up/down inputs to tell a micro-controller what solenoids to switch on and off within the transmission instead of switching the solenoids on and off myself. I would also like to use the tachometer signal to prevent the micro-controller from downshifting into a gear when I'm at too high of an RPM thus preventing engine damage if my paddles or shift lever is bumped in error. I also need to display what gear I'm but I will be leaving that for another time as I will be doing extensive testing before I actually try using this on the track. The switches are straight forward but feel free to correct me on that section if it is off. The solenoid control and engine speed signal are of concern to me. I think I got the solenoid control correct, forgive not having values or specific parts listed it was kind of rushed. If there is anything wrong please let me know how I can design it any better. IDK if the tach signal is at 5v or 12v but it is pulse frequency not pulse width so that's blank for now however I was planning on using an opto isolator to step the pulses down to a voltage more manageable by the controller. The pressure solenoid control will be PWM converted to a 12v higher current circuit but I have little experience working with PWM. I have no idea how to do any of that so that's the second reason I am here. I know this was long winded so I want to thank anyone who even read this in advance.
