Ok I found an old set of Mindblower Speakers in a box cleaning out a room. I'm pretty sure they no loner work. But it got me thinking could I resurrect these, create my own company and start manufacturing them. The company was called Tenna they were around in the late 70's and early 80's and as far as I know they no longer exist. Spent most of the day yesterday drawing it out on the computer, circuit board, components and looking up what they were called. I know nothing about electronics as I was machinist all my life with a little study in mechanical design and using CAD. They are mostly rusted and the parts have no clear markings on them! If they (Tenna) are no longer in operation can I re-do them and sell them without like copy right infringement, name infringement...etc? I would be making upgrades to the old design as they were notorious for failing after about a year with the PCB board being the worse about burning out the embedded wiring between components. But I have a few question I don't know how to get the answers too.
Without the Markings (numbers and ID's) how do you tell what they were?
And if I need to put a meter on them is there a chart that can tell me input, output voltage, ohms or whatever it's call to identify what they are.
I not trying to get you guys to do my work for me just point me in the right direction.
The unit consists of only a few parts;
1. (1) PCB board
2. (1) Transformer
3. (2) Diodes
4. (2) Capacitors, One being a ZSF the other same kind only larger
5. (2) Transistors
6. (1) Coil, I know it's function was to change it from a three wire output to a two wire output cos the first ones hooked up to special speaker with a double coil. Later models used this because the three wire speaker became hard to find or became too expensive and the coil was cheaper and you could now use any speaker on the market.
Any help or feed back would be appreciated!
1. (1) PCB board
2. (1) Transformer
3. (2) Diodes
5. (2) Transistors
