i have a MCP6001.txt file LT spice model . But how to add that .txt file to the LT spice opamp directory
and run
and run
after downloading this i kept this MCP6001.lib file inThe factory model of this opamp is poorly suited for LTspice.
I made a correction for this model.
And
http://www.analog-innovations.com/
MCP6001_JT.zip
Use my symbol MCP6001.asy
The library is inscribed inside the element symbol. No need to use .lib MCP6001.lib.
sir i am completely new to this please can you tell me what to do with this .asy fileUse my symbol MCP6001.asy
Use my symbol.
.lib MCP6001.lib
can i directly run that draft without placing any of the .lib file in to sub folder of Library and .asy into the symI did everything that you would not spoil anything!
[QUOTE = "andhavarapu lokesh, post: 1170070, member: 467994"] can i directly run that draft without placing any of the .lib file in to sub folder of Library and .asy into the sym [/ QUOTE]
Yes, for this I did a special folder. Unzip it and click on the schematic file.
HIi got same error if ran this
by Jake Hertz
by Jeff Child
by Duane Benson
by Jeff Child
