What would the difference between an audio amplifier and an opamp be exactly?
don't they both amplify the signal's amplitude (voltage)?
I want to amplify a signal from an electret microphone to 5V, I believe an opamp should be sufficient right...... Then what's so special about an audio opamp.
Keep in mind that my signal only contains frequencies up to 1760Hz.
Thank you
Thank you
