OK, the BC548 has the opposite pinout of the KST2222--these things get confusing...
http://www.futurlec.com/Transistors/BC548.shtml
Right now, the base emitter junction appears to be open, or the emitter is not connected, because you're getting ~3.9v at the junction of the 10k and 22k resistors when you press S1.Would be either the transistor or the zener diode. Correct? The 1.8k ohm is definitely correct and connected to 12v+, and the other side to pin 2 and the zener.
I've attached a schematic & simulation of the circuit. Note that I've added R9, a 100k resistor from the output of the opamp to the noninverting input; that provides hysteresis, which helps the MOSFET turn off much more quickly. Without the hysteresis, the MOSFET may stay in a resistive state for a period of time; if there is significant current flow through it, the MOSFET will get very hot, and possibly burn up.I can try the 7.5k ohm resistor in series with the POT and neg terminal.
Then it needs some more work.My sealed lead acid battery which is charged by a solar panel for powering lights at night. I wanted this circuit for protecting the battery from over-discharge at night due to a couple cloudy days in a row not allowing a full recharge. Only problem is, the circuit needs me to press the reset button after the charge rises back up.
I am not unfamiliar with this problem, as I have owned them in the past. The best thing to do is disconnect the battery when not in use, and keep the battery float charged.The scooter/motorcycle battery idea was an afterthought. Many people have scooters/motorcycles that have a tendency to get a dead battery.
There are many reasons why we don't discuss automotive modifications on this site, but what most of them boil down to is safety and/or legal reasons.I thought this would have been another good use for this circuit, but obviously more modification was needed to make it reliable.
The point is that we want our members to live long, happy and productive lives in as safe of an environment as we can advise.For whatever purpose someone is making a circuit, that should be no issue for getting help here.(Unless it is highly illegal) We are here for help with circuits. What we decide to use it for is our business.
I like the snowball example.Automotive engineers with years of experience make mistakes ...........non-automotive engineers have of remotely developing a circuit for automotive use, which is one of the most brutal environments on the planet, that a neophyte can build and install, and have a snowball's chance in a hot place of working for any period of time?
You still don't understand.As I said before, your help was well appreciated, and I fully understand all of your concerns. Your 100% correct when you say engineers with years of experience make mistakes when they design a circuit, so what makes me think I won't make a big mistake on a circuit with only a fraction of their experience.
I can pretty well guarantee that the circuit you built will fall apart at any random moment, particularly if subjected to an automotive environment.I do agree that it should not be used on a car because you have no guarantee that the circuit won't cut off power when it should not.
This goes back to proper maintenance. It is your responsibility as the owner of said vehicle to ensure that it is maintained in a manner to keep it corrosion-free and roadworthy. Since many electrical parts of a scooter are exposed, it requires much more maintenance than an automobile does to ensure that the connections, sockets, etc. are clean, corrosion-free and sealed using appropriate materials. "electrical tape" is NOT an appropriate material for anything on a vehicle, unless it's just to cover a rip in the seat.All this being said, there is no guarantee that my scooter would not lose all power due to some other reason (loose fuse holder/loose wire etc), which it has before.
It's not just that the power would be cut. The alternator would no longer have the stabilizing factor that the battery provides, and the output voltage would fluctuate wildly. At best, this would lead to being stranded, and very possibly some quite expensive repairs.I did want this circuit to be able to handle intermittent heavy loads where the battery would normally drop in voltage, but that would trigger the circuit to cut off power.
I guess you're talking about a bilge pump in a boat while one is away.I have lots of other useful ideas for this circuit. I came up with an idea to modify it, and tested it out several times with total success. I took the battery + which feeds the circuit and added a Schottky diode in series with that line to the board. I then added a 15,000UF 25v electrolytic capacitor across the power supply to the circuit. Now when the circuit experiences an intermittent voltage drop of up to 3 seconds, the circuit no longer triggers a cutoff due to the reserve in the capacitor which powers the circuit. The circuit does not see the drop. This can be used for pumps connected to a 12V battery which for some reason fail to turn off and end up draining your battery.
And your qualifications are? Training? Certifications?Your like a broken record.
"the photos you posted of the circuit that you built show a disaster in the making."
That is your opinion, which I TOTALLY disagree with. Just because a circuit was not assembled on a nice computer generated circuit board does not mean it will not work just as good. Especially since it is not an RF circuit.That I know for a fact.
Here, this brief guide should help you improve your soldering considerably:I have never had a board fail, and I have assembled many circuits. If yours did fail, then obviously it was not done like mine. The soldered connections were all done extremely well. No cold soldered joints, board properly cleaned before soldering, proper flux, proper cleaner, proper bus wire.
It's not the fact that it's soldered. It's how it was soldered.As for the heavier gauge wire soldered directly to the mosfet, I would prefer that connection over a socket which can become loose or corroded.
It's damaged. The body of the resistor is supposed to be hermetically sealed. Since the epoxy is chipped, that also means that the component was subject to stresses that makes its' physical integrity suspect.The one resistor you see with a chip in the epoxy at one end....is meaningless. If the chip was in the middle where is counts, you would have a valid point.
It must've been quite a challenge to center the component leads in the vias that were broken in two while you were trying to solder them.As for the board being cut off....I had it laying around and did not want it going to waste, so I made it work.
It should be obvious by now that just "a housing" would not correct the deficiencies that have been pointed out thus far. However, it would make it easier to find the parts that will fall off due to shock, vibration and metal fatigue.Obviously if I decided to use this circuit in a boat/car/scooter or anywhere else......It would be placed in a housing where NO damage would be done to the circuit.
Now that, I believe.The nylon tie was only temporary!
Loctite is pretty good stuff.I could not find my robertson screwdriver to tighten the nut on the small bolt. So I held it in position with that tie until I found the screwdriver later. Oh yeah, Loctite 242 works extremely well on that nut if your so worried about it becoming loose.
Don't be so sure about that. Your scooter motor would vibrate it to death in short order.I also would not bet on my circuits, "falling apart". You would lose.
You didn't seem to get it the first time around, like a lot of other stuff.I see you are still stuck on the alternator / battery issue. LOL. I agreed with you on that already. Get over it, I know its tough.
I don't seem to be the one with a problem. On the other hand, I'm trying to help you to not cause yourself injury or damage to your property, which is what the overriding concern of the forum is. We talk a lot about electronics, but we try our best to make certain that things are going to be safe for our members.Maybe you need therapy to get over it.
That was deliberate not-so-dry humor. My dad and I had a discussion about bilge pumps many years ago; it seemed the foregone conclusion that bilge pump or not, the boat was still going down.If the circuit were used on a boat bilge, then it would not be recommended to use it if you were not going to be around on a daily basis to see your boat.(Example - In your backyard) Use common sense. I have seen countless boats have their batteries destroyed due to deep discharge by stuck float switches, or bilges that were manually activated, and they forgot to turn it off. Oh yeah, even if you don't use this on a boat, your battery will still end up going DEAD if the above happened and your boat will still sink! It will just take longer to do it. LOL This is turning out to be a comedy.
There was no attack.I'd love to see how you treat your friends, after seeing how you attacked me(someone you barely know) over a simple suggestion on how a circuit can be used.
By the way, ad hominem aka personal attacks are not only in violation of the ToS, they are also a demonstration of your inability to present your case in a logical fashion. As I have made in excess of 20,000 posts here in the last several years with better than 90% of them being helpful to people, while you are racking up an impressive record of being argumentative and violating ToS, I'm not terribly concerned about what you think.You really are a miserable person.
At this point, it's still your choice to leave. If you continue to violate ToS, it won't be your choice for long.I'm done with this forum.
Danger, danger - people might actually learn something here!I will make sure I tell others to stay clear, especially in all my future Youtube videos.
