What values of resister and led would work in series with a cheap tone generator, and a 9V? Only needed to check unpowered wiring circuits for shorts.
Do you need the tone generator? Couldn't the LED serve as your indicator?What values of resister and led would work in series with a cheap tone generator, and a 9V? Only needed to check unpowered wiring circuits for shorts.
Many DVM's have an audible continuity checker.What values of resister and led would work in series with a cheap tone generator, and a 9V?
Adding an LED in parallel with the buzzer will not stop the buzzer.#12 mentioned a 1k resistor, as long as a buzzer or other cheap audible would work.
by Aaron Carman
by Robert Keim
by Duane Benson
by Aaron Carman
