or 5 ckts @800w? indeed, total not to exceed 4000??15A*120V*5 = 9KWatts. You're converter is only good up to 4KWatts. You can only run two of your 15A circuits.
I'm thinking standard off the shelf automotive battery chargers from a pawn shop or garage sale. Dirt cheap and plenty of transformer to work with in the 20+amp size units.now tcm has me thinkin "wall warts", there are some big chunky 120-12/15vac units out there, an his math in #13 and #14 sez bout 400va should work, might be an easy score on the cheap like from ebay or amazon, one on each branch ckt at the distribution panel.....
Also, if you use a 12V transformer to make up the voltage difference, as proposed in post #4 and #6, then you'll only needor 5 ckts @800w? indeed, total not to exceed 4000??
The secondary goes in series with the primary on the hot line end. One way it will buck the input voltage down the other it will boost it up. 50/50 chance of getting it right the first time.both sets of windings in series, transformer from batt chrgr. on the bench, line on 115vac side. load side(18vac). . . to where??
See schematic in post two. Think about it and the parts you have and adapt from there.yes? no? maybe-so?
Think about it for a while then tell us what you think will happen?what do you suppose would happen if i paralleled a conductor with the secondary winding to load2. the added conductor would carry most of the amperes, the winding would mostly be "boosting voltage", as in #14
Not necessarily. For the transformers rough continuous VA rating just take its continuous rated amp output( not peak boost rating) times ~15 and call it close enough.last question (for today) 400va/12=33.33amps, so, to guestimate the garage sale battery charger xfmr being re-purposed, the battery leads need to be at least awg 10 size or larger to assume the xfmr inside is large enough.
Thread starter | Similar threads | Forum | Replies | Date |
555 voltage booster | General Electronics Chat | 124 | ||
J | MOSFET voltage booster heat and protection | General Electronics Chat | 10 | |
A | Voltage Booster | Power Electronics | 37 | |
B | The Induction Coil of DC Voltage Booster. | Power Electronics | 7 | |
T | DC voltage booster not working as expected? | Power Electronics | 17 |
by Aaron Carman
by Jake Hertz
by Jeff Child
by Jake Hertz
