https://www.amazon.com/dp/B000FN12M2/ref=biss_dp_t_asn
I have an Lectrasan, the copper wire that joins titanium plates is failing due to corrosion in salt water.
The titanium plates are charged positive and negative and transfer 12vdc current into a brine solution tank for sterilization purposes.
The titanium plates do not wear out, the #10 gauge copper connecting wire does. The copper wire is passed through opened interleaved slots in the titanium plate, a titanium rod would simply screw into the titanium plate along a length of about 4 inches, like the copper wire does. From plate to where it connects to power wires is about 4 inches of length.
I was wondering about using titanium rod threaded into the titanium plate?
The current flow when normally functioning is 18 amps power.
Will titanium rod of that size permit sufficient amp flow to the titanium electrode plates, seeing it has much higher resistance than copper wire?
The idea is titanium rod is going to last pretty much forever compared with copper wire.
The failure mode is heat generated with current flow to the titanium plate eventually destroys the seal allowing brine to contact the copper wire, and that causes the copper wire to break down..
A new titanium electrode for Lectrasan is over $300. So financially you can understand my motivation.
