Instigator, lol!
I am aware of this whole free energy fad that's going on, but I am not going to believe the hype myself. I just want to get some answers, and if you cannot provide them, then please don't provoke people to look at my post negatively. There is nothing wrong with asking questions, thank you.Mods please close this thread! It is OU in disguise.
Whenever someone mentions a diy generator build using neo magnets, its pretty much guranteed to be one of these free energy believers.
Why? Gearing speed up is very inefficient mechanically, and you have multiple stages (multiple gear sets).
Oh, please indulge me. How is it that lubricated magnets are the give away? Do you lube your magnets? I am just trying to get some answers, please don't chime in with insignificant commentary. Thank You."Lubricated Magnets" is the giveaway.
Yes you will. If the coils have ferromagnetic cores then there will be 'cogging' resistance due to the magnet/core attraction. And if you try to draw current from the coils a counter-torque will be generated.My main question is whether I will encounter significant resistance from the magnets as they rotate over the coils.
Yes. Gears allow rotation rate to be traded for torque. If you gear up a first shaft so that it rotates twice as fast as a second shaft then it will only have half the torque (even less, allowing for efficiency losss due to friction) of the second shaft.I remember that certain motor were extremely hard to turn by hand while others were effortless. Is it the gears?
I'm having a hard time figuring out the WHY of this. I've re-read the original post a couple times and I'm still not sure I picture it correctly. Is the idea: A stacked series of 7 pairs of stacked disc rotors, each pair having a stator between them, and the each pair geared up in rpm from the previous?
Yes it is, for the most part.
What is this configuration supposed to accomplish? The emf developed in a coil is proportional to the speed of the magnet passing by it, so most of the available power will be available at the fastest turning rotor pair. Except that the mechanical transmission losses already mentioned will negate that effect. You could wind the coils for each stator differently to extract different voltage/current profiles, but I don't see what that would accomplish. And all the pairs will be out of phase with each other, making this a 7 phase generator?
Also, magnetism is a little like electricity in that it needs a low-resistance return path for the field lines, to maximize the flux. I don't see any allowance for that in the current design. That's a problem common to many DIY PM generators and is not unique to this design.
Good design generators have high efficiency, that means the largest transfer of shaft power to electrical output power.How would you suggest getting the rotors to spin? I'm aware that there would be a lot of friction...
Yes. And a single rotor (or a stack of rotors spinning at the same speed on the same shaft) would work best....
Is it the gears? Would it be more efficient to get the rotors to spin simultaneously, via the power from the solar motor?
