Hello guy's.
I want to start off by apologizing for my bad English it's not my first language
I'm trying to build an automatic fan controller for a PSU project I'm working on.
The idea was to use some kind of comparator or schmitt trigger to trigger the fan to go ON at certain point(around 50°C). The reason I want to use schmitt trigger is so the fan won't constantly go ON/OFF at the trigger point.
For the PWM i was thinking about using a 555 timer. To control the PWM I thought i might use a NTC resistor.
I'm trying to use only one NTC(they are quite expensive here). The problem is I don't seem to be able to use the NTC both for the schmitt trigger and the PWM.
So to sum up:
Build a fan control with trigger point of 50°C and use schmitt trigger. From 50°c upward slowly rise the speed of the fan until the temp is about 80 and then is on full speed.
I will be running this on 12V dc. And I want to keep the cost down as much as possable
I'm open to all idea's how to do this and if someone can point me in the right direction that would be great. I've already tried google and tho i did find a lot of information on this topic none of them suits me the way i was thinking.
P.S. I would rather not use microcontroller so don't suggest it
So to sum up:
