Transistor or relay
Status
Not open for further replies.
vdubin
Joined Sep 22, 2009
7
Hey guys... I am working on a custom taillight mod. I am replacing the standard bulb in my taillights with LEDs. The problem i have is full brightness to be seen during the day will be blinding at night. I was thinking of using a switching relay and having a resistor on one leg, triggered by the tail light circuit to power the brake light funtion. What i have been looking into is using a transistor setup to try for a solid state system that i can keep out of the weather.
Any ideas? The load would be quite small 2-3 amps at 12-14v with a 12-14v trigger.
cork_ie
Joined Oct 8, 2011
428
Discussion of automotive modifications are banned under AAC Terms of Service and are likely to get this thread locked. I would also warn you that bulb current measurement is incorporated in most modern cars.
You can resubmit (or edit) your question in a more non automotive way and get some more general information.
Status
