Basically, this is a "It's not the volts that kill you, it's the amps!" question.
Why does a high voltage shock from a van de graff, or doorknob, or even a stun-gun etc; not kill you? Sure there aren't many charges to be moved, but the amount of current should still be dictated by ohms law. You'd get an extremely high current for an extremely short period of time. Why is such extreme current safe for short periods of time? What would happen if you tried to shock yourself like this many times a second? At what point would things start getting dangerous?
