different batteries in parallel
piracyer
Joined Jun 9, 2012
32
Hi, I kind of struggle with this question for a long time.
What happens when I put two batteries with different voltage rating in parallel?
Such as the circuit I have attached.
I saw one thread that ask about this in the forum, but the answer given is quite simple, saying that the higher voltage battery will charge the lower voltage battery and the lower voltage battery might explode. I am looking for more detailed answers - how the electrons flows in this case? what is the voltage across RL? how is the current distributed at node 1 and node 2? For the simplicity let's just assume the neither battery will explode.
If the voltage across RL is 6 volts, according by many website, why is that?
Also, according to the "All About Circuits Volume1 DC: Chapter 9: Thermocouples section" (http://www.allaboutcircuits.com/vol_1/chpt_9/5.html) the last several paragraphs, applications use thermocouples in the measurement of average temperature between several locations by connecting several thermocouples in parallel with each other. The reason is "The millivolt signal produced by each thermocouple will average out at the parallel junction point."
So why in the case of thermocouples the voltage average out? Why not in the case of batteries?
and please don't just reply saying connecting batteries with different voltages in parallel is dangerous.
Thanks.
w2aew
Joined Jan 3, 2012
219
OK, since you've gotten a lot of advice in the past that told you that connecting batteries of different voltages in parallel can potentially be dangerous - then you already know this part, so I won't repeat it.
A battery is an electrochemical device that has a low internal impedance (generally) and will produce a given voltage. Some batteries are designed to be recharged, some are not. Rechargable batteries can accept current in the opposite direction of the discharge current. Generally, non-rechargable batteries can not - they can be damaged - sometimes violently.
Since batteries have a low internal resistance, connecting batteries of different voltages in parallel *can* cause a LOT of current to flow from the higher voltage battery into the lower voltage battery. The large current could potentially damage one or both batteries. Assuming they survive the large current, and assuming that the lower voltage battery is a rechargable type - then you will ultimately wind up with the larger voltage battery being discharged (dead), and the lower voltage battery getting potentially damaged via overcharging or excess charging current.
You didn't have a picture attached, so the above comments are based just on the description of putting two dissimilar batteries in parallel.
Bottom line - it's almost always a bad idea, unless you control the current, and ultimately intend to charge one battery from the other.
piracyer
Joined Jun 9, 2012
32
Oops, my mistake, :p, forget to upload the picture.
Now it's being uploaded.
Can you talk more about the current and voltage in the circuit and a comparison with the thermocouples?
Thanks!
strantor
Joined Oct 3, 2010
6,798
Lets say in your drawing that both batteries are 9V, and there is no load - delete that resistor. Equal potential, so no current flows between them . Now, change the battery on the left to 6V like you have it drawn (load resistor still deleted). 3V difference. Unequal potential, so current will flow. 3V difference. Let's say each battery has .1ohms internal resistance. So you have 3v being applied across a .1ohm resistor. I = E/R, I = 3/.1 = 30W. 30W is a lot of power for something smaller than a fish stick to dissipate with no heat sink, so it heats right up to explosion temp. Not to mention, the 9V battery is also dissipating as much power, so would probably explode as well.
In reality though, household batteries are so pathetic they will probably go dead before they explode. When I was a kid I used to connect 9V batteries, + to -, - to + and hold them in my hands in cold weather as a hand warmer. I didn't realize how stupid that was, but I never had them blow up in my hand. I'm not recommending you try it, it is stupid.
cork_ie
Joined Oct 8, 2011
428
Each battery can be considered a Randles circuit - see attached schematic. The overall battery resistance consists of ohmic resistance, as well as inductive and capacitive reactance, this varies for each type and size of battery. There are various experimental methods of determining this for any particular battery.
This resistance is generally very low and directly connecting batteries of unequal voltage in parallel will most likely result in destructive currents.
The effect of the external resistance in your circuit is entirely dependant on the internal resistance of both batteries in your circuit.
DMahalko
Joined Oct 5, 2008
189
Series/parallel voltage mismatch problems can manifest naturally in the real world, where large industrial battery systems use these arrangements.
Eventually one or more of the cells goes bad, and that leads to damaging voltage counterflows and voltage drops and charging problems that can damage all the remaining good batteries.
I've tried to document these problems on Wikipedia.
Uninterruptible power supply -- Series-parallel battery interactions
http://en.wikipedia.org/wiki/Uninterruptible_power_supply#Series-parallel_battery_interactions
34,447
Thermocouples connected in parallel will give the average voltage of the two since their resistances are equal for practical purposes. And since the voltage is very low there is no power dissipation problem or other concern about connecting them in parallel.
Batteries in parallel will also give the average voltage output if their internal resistances are equal. But since the resistances are typically so low, the current and power dissipation can be very high due to the current flow from the higher voltage battery to the lower.
Hi!,
Your Question is very interesting.
In your posted circuit batteries and resistor all are in parallel.
You might be trying to know that "All parallel branches bears same voltage,then What if I force branches to have different voltages by connecting battery of different voltages?".
Well...:)
Theoretically, [note:Considering Internal Resistance of batteries] Internal Resistance of Battery is very low as compared to 10Ω.
Initially,You can consider no current will pass through 10Ω resistor.
Now,Two batteries are in negative series and if we know internal resistance of battery then we can calculate current also.
That current will be very very High.
By connecting Battery you can consider you have provided short that bypass 10Ω resistance.
If you have wire that can provide safe path for Higher current then you can try this experiment.
But it's not practical.:p
#12
Joined Nov 30, 2010
18,224
Referring to post#4
Putting a small, square, 9 volt battery in your pocket with some coins will cause enough heat to make you hurry to stop it!
It won't blow up, but you will fear it is going to burn you.
piracyer
Joined Jun 9, 2012
32
Thank you guys for the reply!!
However, I can't resist the temptation to do a little experiment myself.:D
Of course, to ensure my safety, I only connect the circuits for a very short period of time for measurement.
The two power sources I use consist of three AA mercury-free alkaline batteries with same brand. One battery provides 1.5 volt. and the other two batteries are put in series to provide 3 volt.
So here are the result. (See picture 1 and 2)
1. By simply connecting the two power sources in parallel, there is around 0.5A current (the arrow indicate the direction of electrons flow). However, the current starts out at 0.55A and it start to diminish. It keeps diminish about 0.01A per 3 or 4 seconds until I disconnect circuit. So I imagine the current will keep diminishing if I left the circuit closed. I guess this might be explained by cork_ie's post about the inductive and capacitance reactance in a battery that
2. In this experiment, a resistor of 70ohm is placed in the circuit. A current of 0.03A is flowing through the resistor making a voltage drop of 2.16volt. This indicates the voltage from the two sources pretty much average out each other, and the lower power source does apply some power instead just being a resistor in another form, neither is the voltage across the resistor being simply the lower voltage of the two power sources. However, the current flow from the 3v source to the 1.5v source is still about 0.5A.
bretm
Joined Feb 6, 2012
152
That's not something I would conclude from the data. It could just be power supply sag because the 3V source can't satisfy the applied load. The only way the 1.5V would supply power is if the normal chemical gradient inside the battery were in place, and I don't think this happens if the terminals are 2.16V apart. Put a 4.7 ohm resistor in place of the 1.5V battery and see what happens.
WBahn
Joined Mar 31, 2012
30,060
Given just the idealized circuit you have shown, there would be an undefinable (think infinite) current flowing from the 9V battery positive terminal to the 6V battery positive terminal. You can't build an such and ideal circuit, nor is it a reasonable approximation to any circuit you can build. So if you want an answer that has any physical meaning, you are going to have to provide a better model of each battery. At the very least, you need the effective series resistance of each battery. This would let you estimate the initial currents and voltages on the terminals. But, as others have pointed out, the currents will be very high and the charge state of each battery is going to be changing very quickly, thus the internal resistance is going to be changing quickly, too. So your model will deviate quickly from a practical circuit unless it takes this into account.
As for the thermocouples, that is another case where you can't ignore the resistance in the model. Take three batteries that are reasonably close in voltage (say 6V, 6.1V, and 6.3V) and where each has in internal series resistance of, say, 1Ω to keep things simple. Now hook those in parallel. What will the resultant terminal voltage be?
piracyer
Joined Jun 9, 2012
32
Yes, you are right, it could be the parallel resistance being so low, that the voltage has been dropped somewhere else (such as in the internal resistance of the 3v batteries).
Thanks for pointing that out.
piracyer
Joined Jun 9, 2012
32
If talk about the flow of electrons (from negative to positive), I somehow can't get my head around this.
Doesn't the all the electrons flow to the most positive place in the circuit, that's the positive side the the 9V battery?
And can the electrons actually flow through the batteries? or they have to get to the other end of the battery through RL?
WBahn
Joined Mar 31, 2012
30,060
In a circuit, electrons don't all flow to any one place. Everything stays neutrally charged (unless you are talking about some very specific circuits, but even there it stays true at a sufficiently large scale). If an electron leaves one end of a component (any component), then an electron has to enter another end of it. Think of a capacitor. When it is charged, there are not excess (or missing) electrons from the device as a whole. Instead, the external circuit pulled electrons from one terminal and pushed the same number of electrons into the other terminal. The same with batteries. As electrons leave the negative terminal and flow into the circuit, other electrons are flowing from the circuit into the positive terminal. The chemistry in the battery then move those entering electrons toward the negative terminal while increasing their potential energy along the way.
johnyradio
Joined Oct 26, 2012
434
Assuming identical battery types, with identical voltage and current capacities:
  • Average Voltage: Output voltage of parallel cells with be the average voltage of all cells.
  • Normal: It's normal for new healthy batteries to be a little bit out of sync-- their voltages won't always be perfectly identical.
  • Balance: In parallel, they will naturally balance until their voltages are the same. The emptier cells may get warm, but not necessarily damaged.
  • Inrush Current: If the difference between them is large, and if their internal resistances are low, that will cause a large "inrush" current to the emptier cell, which can damage the emptier cell, and reduce it's life or ability to hold a charge. It's not likely to cause a fire or explosion, because it will be limited by the current the fuller cell can deliver. It might be possible to control the inrush current with capacitors or resistors, but i'm not sure. http://blog.hilltech.com/?p=89
  • Fires and explosions are more likely caused by over-charging a cell to a higher voltage than it's rated for (impossible with paralleling identical cells), or a short-circuit.
This vid shows two cells in parallel, with different charge-states. We see current flowing from the fuller to the emptier cell. Note, the cell gets warm, but nothing explodes.
Tonyr1084
Joined Sep 24, 2015
7,900
Consider this: Batteries are sort of similar to capacitors. They both can be charged and discharged (assuming a rechargeable battery). So replace your batteries with two capacitors of the same value (capacitance and voltage rating). Now, charge one cap to 9 volts and the other to 6 volts. Connect them in parallel and the higher charged cap will discharge while charging the lower charged cap. Eventually they should equal out at 7.5 volts.
Now: Consider the batteries. And assume your 6 volt battery won't explode at 7.5 volts. The 9 volt battery will discharge until the 6 volt battery comes up to 7.5 volts, and the 9 volt battery will drop to 7.5 volts. When equal in voltage (electric pressure) no more current will flow in either direction. You can now consider that you have a single larger 7.5 volt battery and your RL.
You can imagine two glasses of water with a pipe connecting them both at the bottom. One glass is filled 9 inches high and the other only 6 inches high. The pipe has a valve between them. When you open the valve the water will flow from the 9 inch glass to the 6 inch glass. Eventually both glasses will be filled to 7.5 inches.
WBahn
Joined Mar 31, 2012
30,060
So are you claiming that if someone connects a 48 V high amperage battery to a 2 V submarine battery that the terminal voltage of each will be 25 V?
And that nothing bad will happen?
Further, by this reasoning, putting a shorting bar across a battery should result in the terminal voltage being reduced to half the open circuit voltage (since a shorting bar is very, very close to an ideal 0 V battery).
WBahn
Joined Mar 31, 2012
30,060
Even if we assume that you can overcharge a battery and its terminal voltage will rise linearly with the overcharge (and this is a VERY bad assumption with any battery that comes to mind), the notion that they will average out to the average voltage is woefully naive.
Does anyone REALLY think that if you put an 1.5 V AA battery in parallel with a 12 V car battery that they will average out to 6.75 V or anything close to it?
Tonyr1084
Joined Sep 24, 2015
7,900
@WBahn In theory.
No, I'd never hook up two different potential batteries. But the thread starter was curious to understand his battery circuit. Addressing ONLY (what I believed what) the question asked I directed the understanding to be an averaging of voltages.
You are 1000% right - putting a 1.5 volt battery in parallel with a 12 volt battery is an ill conceived plan. But I could take your example a step or two further: You wouldn't put a rectifier on a 240 VAC circuit and attempt to charge a 1.5 volt battery with it. Lots of energetic action and heat.
The video posted in the answer above mine - t'was by johnnyradio - illustrated nicely how you can get as much as nearly half an amp between two batteries differing in voltage of only 0.3 volts. That's a LOT of current. But the point was nicely made. The higher charged battery (like my capacitor illustration) will charge the lower battery (capacitor). The TS already stated that he knew better than to try this in real life. He only wanted to understand this a bit better. Hence, capacitors (oh - lets say rated for 16 volts), one charged to 9 volts and the other charged to 6 volts. Both - for the sake of argument were 100 µF. The higher charged cap will discharge into the lower charged cap - and both will end up equaling 7.5 volts (in theory - I know there is ESR and other imperfections to be factored in). But for the sake of understanding - caps. Or two tall glasses of water with a pipe connecting them at the bottom. They will equalize.
Will a 1.5 volt and a 12 volt battery equalize? Probably. But both will probably be heaping piles of acid and other assorted garbage. But yes, in theory they should achieve a matched voltage. IN THEORY! Even if that voltage is - um - ZERO volts, due to massive loss of integrity.
