I want to control 14 BDLC motors for three different Functional application simulataneous. I have programmed & simulated dsPIC33FJ32MC204 Controller for every motor in proteus 7.10. Now I want to command and control all these motors from single USB 3.0 or high speed 2.0 from PC.
Which approach will be best?
1. From all 14 motors I programme I2C data bus to single microcontroller board which transfers data with help of UART(USB) to PC.
2. I should program a 14 port usb hub and from all motors data is transfered through UART to that HUB and from HUB to PC.
I want control of every joint on windows platform, so that many algorithms can be tested, programmed and managed in .Net easily.
If 2 option is better then please tell how prepare a usb hub with Help of Microchip microcontroller,
If 1 option is better then please tell which microcontroller should used for this work.
Thank You.
Thank You.
