I just made a crystal oscilator from the following circuit:
But I seem to have a problem. I have found that I can get these frequencies:
Pin 1- Unkown
Pin 2- Alternation between 64.1KHz and 67.6 KHZ, sometimes 33.3KHz. The duty cycle ranges from 10%-20%
Pin 3- Same as above (as far as I can tell maybe the oscilator can't detect this low maybe?)
Pin 4- 515Hz
Pin 5- 1.02KHz
Pin 6- 258Hz
Pin 7- 2.05KHz
Pin 8- Same as pins 2 and 3
Pin 9- 32.9KHz @ 48.7% duty cycle
Pin 10- 32.9KHz @ 51.3% duty cycle
Pin 11- Clock>
Pin 12- GND
Pin 13- 64.1Hz @ 50% duty cycle
Pin 14- 128Hz @ 51.3% duty cycle
Pin 15- 31.9 @ 50.3% duty cycle
Pin 16- VDD
So here is what I think the problem is.. the circuit says to have a 15MΩ resistor. I used a 10MΩ+5.1MΩ because that is the closest my university electronic store could get me. Everything else is exact I think. My 10p capacitor has a label saying 10k on it but I'm not really sure how to read those ceramic capacitors that are used there.
What could be the problem?
In the end I want 1Hz.
Pin 1- Unkown
Pin 4- 515Hz
Pin 5- 1.02KHz
Pin 6- 258Hz
Pin 7- 2.05KHz
Pin 11- Clock>
Pin 12- GND
Pin 16- VDD
