I have a 480V>120V control transformer that keeps tripping a 6A breaker (installed on the primary) when I turn it on. I installed a temporary fast acting 6A fuse to make sure the breaker is not faulty and the fuse blows, so I know inrush current is >6A and breaker is good. If I hold the breaker in for a couple of seconds it will stay on and I read 1.5A with clam meter, so steady state current with maximum load is well below the breaker trip point. I need something to limit the Inrush current. I was thing a NTC resistor, sound good? I found this one but I'm not sure it will work. does not specify a max voltage, but mentions capacitance at 440V. datasheet says "Thermal Time Constant 194 seconds"; does that mean it will take >3min before it is effectively a short?
I've never used one of these and if someone could recommend me one that would be great. thanks
