Awesome forum, wish I would of found it a long time ago!
First off, I know my bit of circuitboards and electronics. I own a small shop building standalone ECUs for a line of auto engines. However I also have been DJing on the side.
I have been using this power supply with great success. http://cgi.ebay.com/12V-DC-30A-350W-Regulated-Switching-Power-Supply-MW-New_W0QQitemZ390096861039QQcategoryZ58288QQcmdZViewItemQQ_trksidZp5197.m263QQ_trkparmsZalgo%3DSIC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D10%26pmod%3D170595276354%252B310273322890%252B270639263385%26po%3DLVI%26ps%3D63%26clkid%3D6911495395181962290#ht_5663wt_1076
However I had changed my setup and the new setup puts my power supply next to my class A/B amplifier, which obviously puts out a bit of heat.
I didn't have time to install the fan systems I wanted, so I two just working the power supply. I had it running around 4-5 hours and then the amplifier went into Thermal protection mode, obviously not good while DJing live
I grabbed another full size fan and put it on them, I then switched the power off to the power supply and I hit it back on, I got about 4-5 seconds of sound then BAM nothing, no lights or anything. I ended up going to my backup system for the rest of the night.
Today, I took the power supply out for inspection and ran across this little problem...
Which went right above the glass fuse in this picture...
I assume this might of saved the PS from death, but I cannot ID the component. I know some NTCs are inrush limiting devices, but I don't have any experience with them and with the thermistor in really bad shape I have no idea what to replace it with.
In all honesty, I am not entirely sure what broke it. Was it faulty to start with? Or when I turned the system back on too soon, the thermistor was already to warm and broke?
The only thing printed on the circuit board is NTC1, as well.
And if anyone has any other suggestions as far as a 15v high amperage power supply I am open to suggestions, but I don't have a great network of people who know much about this stuff locally, its a blessing I found this site
