Please go through the attachement and tell me that in picture the 2 image is same as 1 or its done wrong connections in 1 as in 2 please tell me confirm a bit confused.
I thought you simply wanted to know what the pads for the IRF540 itself should look like?In the layout you attached, the Gate and Source are not connected, while in my schematic it is connected.
The upper IR2111 pin 7 is connected to one end of R4, and the other end of R4 is connected to the gate of Q1.A second point is that from pins 4 and 7 of the IR2111, a 47 ohm resistor is connected and wire drawn to IRF540.
Does this explanation help at all?I just want to know to which pin wire is connected, as I don't understand this thing ??
His diagram is a single sided board. The green pads are separate to mark them as component pads, think of them as blue / copper. The white items are the top side components, there are no traces on the top side of the board.Sorry for typing short words it was greatly explained but in the figure layout its a bit cobfusing overlaps as double sided board as i know only single sided can u make a layout for me to understand for a single side board
