Normally, the voltage has all the weight when having a shock. Some people think the effects are due to current instead of voltage. But if we think in a car battery, it can give 600A, more than enought to kill suposely, but nobody gets killed by touching both terminals of such battery.
Then you ask: "Getting a shock throught a high value resistor gives less damage! How do you explain that?"
You should think that the human body also has a resistance (a high one indeed). When you get a shock throught a resistor, you feel less effects because your body resistance in series with that resistor acts like a voltage divider. Thats why the higher the resistor value is, the less voltage you will get, and the less of a shock you will feel.
Moreover, remind that you can be killed when touching the terminals of a 230V outlet.
That's all very close to what was in a book about electronic components and measurements, by Roberge, that I had for my first EE lab course, "way back when" (circa 1975).2mA is a little low. This what I've been tought:
From 0 to 0.5 mA - no sensation
1 mA - threshold of perception
From 1 to 3mA - weak sensation
From 3 to 10 mA - painful sensation
10 mA - threshold of muscular contraction in the arms
30 mA - threshold of respiratory paralysis
75 mA to 100 mA - threshold of cardiac fibrillation (probability 0.5%)
250 mA - cardiac fibrillation with 99.5% probability (for an exposure time of 5 seconds)
4A - threshold of cardiac paralysis (sudden stoppage of the heart)
5A - burning of organic tissues
The magnitude of the applied voltage necessary to produce dangerous current values depends on the resistance of the body, where body resistance varies between wide limits. Between hand and foot, for example, assuming good electrical contact, the resistance is about 500 Ohms , excluding skin resistance. The skin resistance varies from about 1000 Ohms /cm^2 for wet skin to about 3 x 10^5 Ohms /cm^2 for dry skin.
It is some 3 and a half years since I posted that information up, but this was the information provided to me as part of an electrical safety course during my degree (which means it possibly was adapted from the Roberge book).That's all very close to what was in a book about electronic components and measurements, by Roberge, that I had for my first EE lab course, "way back when" (circa 1975).
Ok. Lets do the test. 1900K is my resistance when dry (sometimes I can't read it).The "load" dictates the current flow. Remember I = E/R?
Measure the resistance between your two hands by pressing the ohmmeter leads between your thumb and forefinger.
i understand what u are trying to say.Ok. Lets do the test. 1900K is my resistance when dry (sometimes I can't read it).
Now, it I wet my fingers my resistance drops to 330K. That is not sufficient to be electrocuted by a car battery. The current here would be 0.036mA. Then again, is the voltage that motivates the current flow.
In these conditions, I would be surely death by touching a 230V AC outlet (peak voltage is 325V, 220V is the RMS value). But the RMS current would be only 0.6mA, not enough to kill. I think the current theory doesn't apply very well to all situations.
If you consider a current source you have to consider that a current source is a almost infinite voltage source in series with a limiting resistor (that limits the current). Although, I can see your point.but if u consider a current source the scenario changes altogether.
one more thing is that ,as already discussed by mr dave and mr gooty
shock magnitude is defined in terms of current.
but then again depending on circumstances, since we generally
deal in with voltage sources the warnings are written in voltage terms
to give an idea abt the severeness of the shock.
one thing i wud like to bing forth here is that without flow of current no shock will be experienced irrespective of voltage or voltage difference.
I agree you wouldn't be affected by that 12 volt battery. The humid enviroments that expressed the 300 ohm body resistance would be those who work at sea, surrounded by salt water.Ok. Lets do the test. 1900K is my resistance when dry (sometimes I can't read it).
300 Ohm is very low for human body resistance. Are you sure about this value?I agree you wouldn't be affected by that 12 volt battery. The humid enviroments that expressed the 300 ohm body resistance would be those who work at sea, surrounded by salt water
how ,were these values arrived at?2mA is a little low. This what I've been tought:
The danger of shock from a 450-volt ac electrical service system is well recognized by operating personnel. This is shown by the relatively low number of reports of serious shock received from this voltage, despite its widespread use. On the other hand, a number of fatalities have been reported due to contact with low-voltage circuits. Despite a fairly widespread, but totally unfounded, popular belief to the contrary, low-voltage circuits (115 volts and below) are very dangerous and can cause death when the resistance of the body is lowered. Fundamentally, current, rather than voltage, is the measure of shock intensity. The passage of even a very small current through a vital part of the human body can cause DEATH. The voltage necessary to produce the fatal current is dependent upon the resistance of the body, contact conditions, the path through the body, etc. For example, when a 60-hertz alternating current, is passed through a human body from hand to hand or from hand to foot, and the current is gradually increased, it will cause the following effects: At about 1 milliampere (0.001 ampere), the shock can be felt; at about 10 milliamperes (0.01 ampere), the shock is of sufficient intensity to prevent voluntary control of the muscles; and at about 100 milliamperes (0.1 ampere) the shock is fatal if it lasts for 1 second or more. The above figures are the results of numerous investigations and are approximate because individuals differ in their resistance to electrical shock. It is most important to recognize that the resistance of the human body cannot be relied upon to prevent a fatal shock from 115 volts or less—FATALITIES FROM VOLTAGES AS LOW AS 30 VOLTS HAVE BEEN RECORDED. Tests have shown that body resistance under unfavorable conditions may be as low as 300 ohms, and possibly as low as 100 ohms from temple to temple if the skin is broken.
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
