Short range TV Transmitter
bertus
Joined Apr 5, 2008
22,992
Yes, you are right.
The circuit round Q1 is the audio modulator.
As Bill said do not forget to mount C3.
Greetings,
Bertus
nerdegutta
Joined Dec 15, 2009
2,689
Thanks.
I appreciate your time and effort.
Beside studying company economics, this will be my upcoming weekend project.
bertus
Joined Apr 5, 2008
22,992
Does it also say someting about the coil in the oscillator?
With the current transistors a VHF channel can be used, most preferable channel 2 to 4.
If you want to go on higher channels other transistors should be used.
Greetings,
Bertus
nerdegutta
Joined Dec 15, 2009
2,689
I found the same circuit on another site. There it said that L1 should be 4 turns, 6mm core turn with 24 swg.
knowitall
Joined Jan 10, 2010
17
You will go nuts trying to keep the Osc. stable, especialy if breadboard.
My advice is to use an old rf mdulator from a throw away V.C.R.
There not hard to spot, or to wire up, old video games , pong ect. would also use such a device, output is selectable on CH. 2 or 3.
nerdegutta
Joined Dec 15, 2009
2,689
Hi.
I thought I would breadboard it, and check the frequency with my frequency counter. A DVM13MC2 bought from www.jameco.com and check.
I have a buch of crystals laying in my drawer, can I somehow hook it up to make the Oscillation more stable?
Thanks for the answer.
bertus
Joined Apr 5, 2008
22,992
Breadboarding a RF circuit is not so good idea.
The stray capacities will give a lot of trouble.
A while ago I posted a link to the "manhatten style prototyping"
http://forum.allaboutcircuits.com/sh...9&postcount=30
This hold a kind of inbetween the breadboard and the dead bug.
Becouse the wiring can be shorter as in the dead bug style, it is fine for RF.
Greetings,
Bertus
nerdegutta
Joined Dec 15, 2009
2,689
Hi, Bertus.
Yes I remember that post. Read the page a few times. I think I will take the time to draw and etch a PCB for this, since the oscillation is so important.
Is it possible to use a crystal to make the oscillation more stable?
nerdegutta
Joined Dec 15, 2009
2,689
Thanks.
Now I have a lot of reading to do. (Lucky me, I can print the web page to a PDF file, transfer it to my Kindle, and read it in bed, just before i watch NCIS :))
Is there any equivalent transistor for the BFR91?
