equivalent transistor for 2sc2078
whale
Joined Dec 21, 2008
110
hello friends,
can any guess me an equivalent transistor for 2SC2078,
can i use BD243C as an alternative?
i have attached the data sheet for both 2SC2078 and BD243C.
bertus
Joined Apr 5, 2008
22,276
I would say no.
The 2sc2078 is an RF transistor.
In the datasheet of the BD243C there is no maximum frequency given.
The BD is an audio transistor, as far as I know.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,276
Take a look in the table from my local supplier:
Rich (BB code):
BIPOLAIRE TRANSISTOREN:
2N706       HF/VHF metalcan
2N709       HF/VHF metalcan
2N1613      HF/VHF TO39
2N2219A     Medium power NPN
2N2905A     idem PNP
2N2907A     pnp hf/vhf
2N2369      =BSX20  video/switching
2N3439      video
2N3553      175 MHz 2.5W tx driver/output
2N3632      28V 14W VHF
2N3866      2W VHF origineel Motorola!
2N4031      pnp 0.8W
2N4045      Precisie dual NPN metal can
2N4427      VHF med.power metalcan
2N4031      pnp 0.8W
2N5108      TO39 1W @ >1GHz
2N5109      =BFW16A breedband tot 5 GHz
2N5179      VHF metalcan
2N5322      TO39 PNP =BSS17 100V 2A 10W
2N5401      HF Transistor
2N5551      Video/RF med.power 160V 0.6A 0.625W >100MHz TO92
2N5589      3W 12V VHF =2N6080 keramisch
2N5590      10W 12V VHF =BLY88C
2N5591      zie BLY89
2N5643      40W 28V VHF =2N6199
2N5946      10W UHF 12V zie BLW81
2N6081      VHF 15W 12V = BLY88C
2N6083      VHF 30W 12V
2N6084      BLW60C 60W @ 100MHz, 50W @ 175 MHz (low gain: 6dB)
            zie ook MRF240
2N6166      100W VHF 28V
2N6199      =2N5643=B25-28 25-45W 28V VHF
2SC1306     Driver, RF eindtrap zie 2SC1969
2SC1678     3W PEP to 50MHz TO220
2SC1885     zie BF420
2SC1945     =2SC2509=MRF479=2SC3133 RF Power tot 30 MHz, 15W, TO220
2SC1946A    (MRF1946) verbeterde 2SC1946 VHF 12V 40W
2SC1969     RF power TO220 = MRF475 orig. Mitsubishi
2SC1969     Second source
2SC1970     TO220 RF power orig. Mitsubishi
2SC1971     Origineel Mitsubishi
2SC2166     6W TO220
2SC2290     Power
2SC2509     =MRF479 zie 2SC3133
2SC2547     Transistor
2SC2879     Power output orig.Toshiba
2SC3101     =MRF630 3W 12V UHF TO39
2SC3133     TO 220 final see 2SC1945
2SC3240     Toshiba RF power transistor
2SD666      Transistor
ABH711585   RF power
AT30511     NF=1.1 dB bij 1 GHz (vanaf 2.6 V voeding) SOT143 (4pin smd)
AT30533     idem in SOT23, zie BFR181
AT32011     Low noise sot143 NF=1 dB & Gp=14dB @ 1 GHz
AT42035     keramische behuizing van AT42085
AT42086     Super low noise high level
B12-12      12W VHF 12W
B25-28      =2N6199=BLY93C 28V 25W VHF
BF199       NPN universeel HF
BF324       PNP HF
BF370       NPN HF voor SAW filters
BF420       NPN 300V 50mA 0.39W 60 MHz
BF450       PNP HF TO92
BF451       PNP HF TO92
BF494       PNP HF TO92
BF599       smd versie van BF199 > zie BFS20
BF820       smd sot23 300V 50mA 80MHz npn
BF821       idem pnp
BF979       PNP Ft=1.3 GHz 20V
 BFX34       120V 4A 100MHz
BFY90       VHF metalcan =BFX89
BLT82       3W @ 900MHz SO8
BLU45-12    45W
BLU15-12    zie MRF654
BLU98       1W @ 900MHz zie MRF581
BLV11       15W VHF 13,5V
BLV20       8W 28V VHF
BLV21       15W VHF 28V CL. A/B/AB/C
BLV25       108 MHz 175W 28V
BLV32F      Lin.VHF-high Po-sync=13W @ 225MHz Gp=17dB Range=50-250MHz
BLV33F      Lin.VHF-high Po-sync=22W @ 225MHz Gp=15dB Range=50-250MHz
BLV75-12    zie MRF247
BLV80-28    VHF 80W 28V
BLV92       4W @ 900 MHz
BLV2045     30W @ 1950 MHz 26V
BLW31       13.8V high gain 10dB 28W VHF
BLW40       zie MRF240
BLW60C      60W @ 100MHz zie ook 2N6084/MRF240
BLW80       4W 470 MHz 12V
BLW81       10W 470 MHz 12V
BLW83       =MRF426 30W PEP 28MHz
BLW85       =MRF224 45W 12V VHF (=BLW60C maar "platte" behuizing)
BLW86       5-50W PEP 1.8-28MHz, also VHF: 45W class B (28V)
BLW95       160W PEP 1.6-30MHz 50V
BLW96       200W 50V
BLW97       =MRF422=TH416 175W 28V
BLX13       SSB cl.A/AB 25W = MRF426
BLX15       Splinternieuw, orig. Philips verpakking!
BLX68       8W UHF 12/13.8V
BLX69A      20W UHF 12.5V
BLX94A      25W UHF 28V
BLY55       Rare power transistor 4W VHF
BLY87A      zie B12-12
BLY88A      Als BLY88C maar zwarte top
BLY88C      14W VHF 12V keramisch zie 2N6081
BLY89A      25W VHF 12V
BLY89C      zie BLY89A of KT920W
BLY92A      15W VHF 28V zie KT922B
BLY92C      15W VHF 28V zie KT922B
BLY93C      25W VHF 28V zie 2N6199 / B25-28
BLY94       60W VHF 28V
BM30-12     30W VHF 12V 2 gats
BSP19       smd NPN 400V 1A Ft=70 MHz
BSS61       p darlington + diode
BSV64       npn
BSV76       npn
BSW66A      npn
BSX20       zie ook 2N2369
BUS12       850/400V 12A =BUX48
BUW13A      =BUS13A 1000/450V 175W
BUZ54A      zie FETs
KT920B      =BLY89C 22W VHF 12V keramisch
KT922A      300 MHz 28V 5W stud
KT922B      =BLY92 200 MHz 28V 15W stud
This list is for comparisson of the transistors.
Hope it helps.
Greetings,
Bertus
