I do projects in front projection. I am now playing with DLP projectors and LEDs with low forward voltages and high current. 3-3.5v and 9A current. I have built a small circuit using:
1 x LM317 + heatsink
1 x 1.2ohm Resistor
SST-90 LED
Power Supply 5.75v 3A
Diagram:
R1 = 1.2ohm
LED = 3Vf (up to 9A)
Vdrop over LM317 2-3.5v (haven't measured yet)
I = 1A
This lights the LED but I am looking into ways to make it much closer to a 9A circuit. Been reading and apaprently I can use some transistors to boost the current output with a LM317 in voltage regulation but I cannot find any examples using constant current. I have very limited knowledge when working with electronics. I am slowly reading the Free Circuit Textbooks. I was wondering how you would implement a Transistor into this circuit and still use constant current.
As this is a learning exercise as well as a front projection project I don't mind other suggestions but working with the parts I have here I would be hard pressed to find another Regulator such as LM338 (3A). I am looking around through my part bins though.
Any suggestions/ideas would be appreciated and would help me learn more about this power supplies.
1 x 1.2ohm Resistor
SST-90 LED
Diagram:
R1 = 1.2ohm
I = 1A
