show work
1. [(ef)' +ab+c'd] (ef)
0+abef+c'def
abef+c'def..
What were you suggesting to the OP to help him find a solution? It appears that you worked out the problem for him....i was just trying to suggest him a solution that could probably guide him to a more accurate answer.
Yes, the above mentioned program shows the minterms of the problem and your solution to both be 2-7 10-15 , so your solution is correct.b+bcd+b'cd+ab+a'b+b'c=b+b'c=c+bc'
>>b(1+cd+a+a')+b'c(d+1)
>>b+b'c
or b(c+c')+b'c
>>c(b+b')+bc'
>>c+bc'
