Hello all.
I have found these forums very useful for reference in the past, but this time I have a project that even my google skills couldn't solve. Just a quick note, I am the noobest of the noob when it comes to electroics, but I did try in earnest to educate myself before posting here.
My (simple) project:
I am wiring up a simple LED to a tattoo machine. If you have never seen a magnetic coil tattoo machine, it is of an extremely simple construction. There is a power supply, a switch, and the machine itself. When the switch is activated, current runs through the machine and it moves. The speed of the machine is controlled by adjusting the voltage on the power supply up or down. This is where my project gets derailed.
Normally when wiring an LED all you need to do is calculate your resistence and plug in the proper resistor to avoid smoking your LED and you're all set... but for this machine, the voltage is constantly being adjusted - in my case anywhere from as few as 8 volts to as many as 15 volts.
The LED I want to light up is a bright sucker - 5000mcd. (Vf:3.2-3.4, If:20mA) pretty standard though. This should light up my immediate work area brilliantly.
In this case, the required resistance would change every time the power supply was touched (which during a single tattoo session can be quite often) so maybe resistors aren't the way to go. I would be happy to post pictures or diagrams if it is useful in explaining what I'm trying to do.
Here is a link for what I am trying to make: sorry it's an ebay link but it will give you an idea
http://cgi.ebay.co.uk/NEW-Tattoo-ma...ItemQQimsxZ20090730?IMSfp=TL090730143001r4715
Thanks in advance!
(PS - some guy here in my country is trying to sell these things for like $60 even though they seem to cost only about $2 in parts - that's why I'm so keen to make my own)
Thanks in advance!
