Ok, so I don't really know a whole lot about circuits so I'm probably asking some really basic questions.
I work for a company that analyzes oil samples. We want one of our machines to mix the samples by rotating oil containers from horizontal to vertical, back to horizontal, to vertical in the other direction, and then back to horizontal. This process should repeat itself until the machine is turned off. We'd rather not use mechanical parts like toggle switches because we don't want the machine to break down over night when no one is there.
So would something like a time delay relay be plausable? Like you'd set the time, plug the machine in so the motor starts to rotate one way, then when the time is up, the motor rotates the other way. Can a relay do this? I'm guessing it would have to be DPDT and have a repeat cycle. Is there anything else you guys would suggest that might work better, even if it is mechanical? Thank you!
