Im wondering if anyone here may know of a simple electronic method, circuit, or perhaps integrated circuit that would provide an indication that a small load, around one tenth of an amp, has been turned on. Contacts closing in a relay or optically isolated switch would be perfect as only the analog state of the load needs to be sensed by a typical PC. Measuring the actual amount of current is not important.
The sensing circuit or device cant tamper with the load it is sensing so a current transformer such as the CR19 would have seemed to be the perfect solution. However, based on my experiments, before these transformers generate enough current to even turn on an LED, the load its sensing needs to be drawing at least one amp.
Therefore could the small amount of current generated by the current transformer be used to trigger a transistor or perhaps be amplified? It should be mentioned the load can draw as much as 20 amps so the device or circuit may require some type of over current protection as well.
