Did you change components, or miss a connection?it doesnt work in simulation... why is that??
I believe you meant "add a 50k resistor in series with C3" ... which is basically what reconnecting R5 properly would do.Your circuit is clipping because it is driven from the very low impedance of the generator instead of having about 50k ohms in series with its input from the volume control.
Add a 50k resistor in series with R3 and turn down the generator's signal level.
Yes, in series with C3.I believe you meant "add a 50k resistor in series with C3" ... which is basically what reconnecting R5 properly would do.
i had done this but nothing particular happened.. the power gain decreases. but the waveform is still the same.Your circuit is clipping because it is driven from the very low impedance of the generator instead of having about 50k ohms in series with its input from the volume control.
Add a 50k resistor in series with C3 and turn down the generator's signal level.
If the waveform is still clipping, you need to increase the attenuation at R6. Change the % of the pot. First try 25%, then 75%. One should be better, the other worse.i had done this but nothing particular happened.. the power gain decreases. but the waveform is still the same.
by Jake Hertz
by Jake Hertz
by Aaron Carman
