zvs induction heater issue
Discussion in 'The Projects Forum' started by lokeycmos, Dec 9, 2009.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    i built this circuit http://kipdev.nl/labs/wp-content/images/zvs_driver.png for a flyback driver and it works great! i can pull some wicked arcs with it. the mosfets dont even get remotely warm. ive been researching online about using the same circuit for an induction heater. i tried it for about a 10 second run as induction heater. the screwdriver got to hot to touch, but the MOSFETs got smoking hot. I tried it from 4+4 turns upto 7+7 turns. am i missing something or is there something i can do to modify the circuit so the FETs dont burn up?does the guage of the wire matter? thank you in advance
  2. lokeycmos
    Apr 3, 2009
    432
    7
    anyone have any ideas?
  3. ams-laser
    Feb 27, 2009
    i hope we get some answers i have same question as the tread starter
    any answers
    Regards
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    Induction heaters use VAST amounts of current. Your flyback device is a high VOLTAGE system.....great for DIELECTRIC heating, not induction heating!
    YOu need a stepdown transformer at the very least....to a mere fraction of an ohm.
    eric
  5. ams-laser
    Feb 27, 2009
    im using a zvs flyback DRIVER not driving a flyback but instead just the primary coil and as core the pice to be induction heated.
    please advice
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps you could post the circuit.
  7. wolf08
    Dec 14, 2009
    14
    you need to take the core from a flyback wrap a 5+5 winding on it and then wrap about 5 to 8 turns of think gage wire on the other side. that gives you AC at a low voltage but at high amp
  8. AfdhalAtiffTan
    Nov 20, 2010
    117
    11
    Maybe it's caused by your diodes... :p
    At least, that what's happened to me before. :rolleyes:
    Use a faster diode... :D
