Hello. I joined here to look for some insight ... I am a hobby blacksmith, and, as such, my electronics knowledge is not the greatest. However, since we are in the future, I have discovered there is such a thing as induction heating and the use of this technology by other blacksmiths. The sort of induction heater often used is the Chinese-made 15kW, 30-80kHz type - LH-15A is the model name, I believe. I can provide a link for reference. Buying exotic commercial machines from China is out of my price range, however, and I'm looking into alternatives.
One that I have found is a little board with a coil described as "flyback driver, ZVS - 1000w". I understand the schematic to this type somewhat, but I do not know how robust this could be. From what I understand, it's probably a much higher frequency (probably ok for my purpose), has a much smaller tank and probably less mosfets. I don't need this thing to run 24/7, but I would probably put many heats through this (4-5 hours of use a week) and heat stock no larger than 2-3" in diameter. I just need it to suffice. The one that I am looking at has no power supply - I am capable of rigging up some sort of DC power supply and have AC220v/60a readily available in my shop. I can make a water-cooling and air-cooling system.
I'm curious if this would work for my purposes... and, if not, might it be modified to suit? This would be a huge money and time saver for me. Plus, 3000F coal fires in the summer aren't that comfortable!
Thank you,
Kevin
Thank you,
Kevin
