ZIP (Zig zag in-line package) sockets?
Discussion in 'General Electronics Chat' started by Kenny99, Nov 9, 2013.
  1. Kenny99
    Jun 14, 2012
    Hi Folks,
    Would anyone know of a source for the ZIP style IC sockets? I have a rather expensive IC which comes in ZIP style packaging. I'd prefer not to solder the pins directly, but I have been unable to find any source of sockets for these. Would it be possible to use two 9 pin SIP sockets and stagger them a bit or would the pin spacing be off? Even a ZIP to DIP adapter socket would suffice, but have not found any of those either.
    Thanks!
    Ken
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I'd just be guessing without seeing the actual mechanical drawing of this part.
    Got one to post?
  3. BReeves
    Member
    Nov 24, 2012
    412
    64
    Probably talking about an Audio or Stepper Driver IC. Most I have seen have larger pins than a standard 74XX IC. Never seen a socket but that doesn't mean they don't exist.
  4. Kenny99
    Jun 14, 2012
    Hi Ernie,
    Thanks for the reply. Dimensional drawing is attached here. Seems that SIP sockets might not be viable based on the pin spacing of the ZIP. Hoping there might be something that will work though.
    Ken
  5. kubeek
    Sep 20, 2005
    4,691
    806
    The pin spacing seems to be standard 100mil, so no problem with normal SIP sockets. If the pins fit in the socket holes then you should be ok.
