Zin of 3 Lossless Transmission Transmission Lines
Discussion in 'Homework Help' started by Jess_88, May 25, 2011.
  1. Jess_88
    Apr 29, 2011
    174
    Hi guys :)
    I'm having a little difficulty determining the input impedances for the circuit
    I need to determine, when the lines are disconnected
    1)Zin looking into line 1 towards the 200Ω load.
    2)Zin looking into Line 2 towards the short circuit
    With lines RECONNECTED
    3) Zin looking into line 3.
    For question 1 I have
    Zin = Zo[(ZL + jZotanβl)/(Zo + jtanβl)]
    and l = λ/4 and β = 2π/λ
    βl = π/2
    or (Zo^2)/ZL
    but I don't know what Zo is???
    For question 2 I have.
    Zin = Zo[(ZL + jZotan(π/2))/(Zo + jtan(π/2))]
    ZL = 0
    Zi = Zo[(jZotan(π/2))/Zo]
    =jZotan(π/2) = ∞
    so it appears as an open circuit
    I have no idea how to approach question thee :(.
    would it be λ/2 wave length for both line one and line two?
    how on earth do I fined Zo for my calculations???
    thanks guys:)
  2. Jess_88
    Apr 29, 2011
    174
    I just noticed I have a typo in the thread title... sorry :S
    So doing a little more looking around and this is what I have.
    It appears to be a dipole antenna feed configuration. right??
    And for part three of my question (impedance input at line 3) it looks like some similar questions I found online, which used line one and line two in parallel.
    Would I also do this for my circuit configuration?
    I'm still lost when it comes to the line impedances Zo.
  3. Jess_88
    Apr 29, 2011
    174
    Is this question even possible without the transmission line impedance or a operating frequency???
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes it is possible.
    The quarter wave line (or quarter wave transformer) has the well known property you noted - Zin=(Zo^2)/ZL.
    The shorted quarter wave line has infinite impedance. This part of the circuit will therefore have no effect on the rest of the circuit.
    Zin for the quarter wave line 1 terminated in 200Ω will be (Zo^2)/200.
    This impedance will be the load referred to the input quarter wave line 3.
    So what impedance will you see with a quarter wave line [with characteristic impedance Zo] terminated in [(Zo^2)/200]?
    Jess_88 likes this.
  5. Jess_88
    Apr 29, 2011
    174
    nice!
    so Zin on line 3 = ((Zo^2)/ZL) where ZL = (Zo^2)/200
    so Zin(line 3) = 200 ohms right?
    but how can you determine the input impedance of line 1 without Zo
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes 200Ω is correct.
    You can't find the actual numerical value of impedance for line 1 - you can only state the impedance in terms of Zo.
  7. Jess_88
    Apr 29, 2011
    174
    ah ok, thanks :)
