Zigbee Soil moisture sensor project issues
Discussion in 'Embedded Systems and Microcontrollers' started by Kahoko, Jan 20, 2016.
  1. Kahoko
    Jan 20, 2016
    6
    In a project I am doing, I have to send analog readings of a soil moisture sensor through zigbee. I have connected the sensor Vcc to 5v and ground; the zigbee Vcc to 3.3v and ground. The analog pin of sensor to Txx pin of adapter on which the zigbee is mounter. On the coordinator zigbee, i/o packets are being recieved..but it is always giving value of "020a" or "020b" irrespective of the data from sensor. I have also fed the analog data of sensor through voltage divider to keep it within 1.2v range..can you suggest what I am doing wrong??
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Hi Kahoko, welcome to the forums.
    Your question is a little vague. Can you give more details o what specific parts you are using?
    And a schematic always helps too.
  3. Kahoko
    Jan 20, 2016
    6
  4. Kahoko
    Jan 20, 2016
    6
    The zigbee is mounted on a 5 pin adapter so I have connected the analog pin of sensor to tx pin of the adapter
  5. Kahoko
    Jan 20, 2016
    6
    The adapter has only 5 pin: reset, tx, rx, gnd and vcc
  6. Kahoko
    Jan 20, 2016
    6
    The configuration at router are:
    atid 5d2
    atdh 0013a200
    atdl 40d6a83f
    atjv1
    atd02
    atir64
    atwr
  7. Kahoko
    Jan 20, 2016
    6
    atid 5d2
    atdh 0013a200
    atdl 40d6a83f
    atjv1
    atd02
    atir64
    atwr
