ZigBee - is it worth to learn about?
atferrari
Joined Jan 6, 2004
4,771
I run across several posts and articles about ZigBee in the last weeks, so I started to read about it.
Started to consider implementing a basic application to gain some familiarity.
I would like to hear any comments, even if brief about actual usage of ZigBee.
Simply put: is it worth?
sirch2
Joined Jan 21, 2013
1,037
I did a bit of background research on zigbee for a project I was planning a while ago (it's on the very back burner at the moment). The conclusion I came to was that zigbee modules in small quantities are expensive so it is only worthwhile if you really need mesh networking and secure comms. There are plenty of other low cost options if you want point-to-point and don't care about security.
enggricha
Joined May 17, 2014
89
I second sirch2 ... depends on the application. I use Zigbees for some of my industrial sensor network kind of requirements, but then those projects are well funded and very critical
ErnieHorning
Joined Apr 17, 2014
65
The DIY Christmas guys use these for one-way transmission. The pro version is used strictly as a transmitter (higher power) and the non-pro versions as relievers (they’re cheaper). Supposedly these can go for about a mile. They’ll do 57.6Kb without any buffering, 8-bit, no parity and 2 stop bits.
Some people have used these to successfully control the lights of houses on a street several blocks long.
There’s a project in the works to add buffering to allow the full 115Kb rate, because the maximum over the air rate is 60Kb. There may be a possibly to go up to 250Kb and allow some DMX light control.
