Can the Virtual ground cancel out the AC signal and just leave you with a DC voltage? or DC offset voltage?
NO. A virtual ground has no AC signal component.Can the Virtual ground cancel out the AC signal and just leave you with a DC voltage? or DC offset voltage?
I don`t think this is a correct statement.NO. A virtual ground has no AC signal component.
How can it amplify zero volts on the input pin?It means you are measuring zero volts on the input pin because it actually HAS zero volts on it.
Zero volts = Zero currentIt isn't amplifying zero volts, it's amplifying the current that came in through the input resistor.
So, what you're saying is that every 120 volt AC appliance in the world uses no current because one side of their power cord is connected to ground. Zero volts = zero current, therefore, all machines with one wire grounded run for free.Zero volts = Zero current
That's the definition of ground, a reference point, usually chosen by the designer. We could just as easily attach the positive terminal of a 9 volt battery to this alleged ground, see that the other end of the battery is 9 volts more negative than what we were calling ground, and name THAT point to be "ground". Now the op-amp will have +9 volts on both of its inputs, and it won't amplify the 9 volts, either. It will only amplify the current arriving through the input resistor.so the input pin of an op amp = zero volts = a Reference? so it's a zero reference?
How can I see some voltage on the negative input when using my DVM meter to measure the voltage?If you really want to see some voltage on the negative input of an inverting Op Amp circuit, tie the non-invetrting input to the wiper of a potentiometer.
Connect the black lead to whatever we're calling ground today and touch the red lead to the pin you want to measure.How can I see some voltage on the negative input when using my DVM meter to measure the voltage?
Sorry to say but this is DEFINITELY wrong.It means you are measuring zero volts on the input pin because it actually HAS zero volts on it.
I have given a numerical example in my post#18 (at the end).The input pin has millivolts? , microvolts? or nanovolts?
Right.........and you will notice that the virtual ground voltage becomes large as frequency increases. This is because the op amp gain decreases as frequency increases.
and you're explaining 10 to 50 uV to a person that needs instructions to put the black wire on ground and the red wire where he wants to measure?Sorry to say but this is DEFINITELY wrong.
by Aaron Carman
by Jake Hertz
by Aaron Carman
