Hi, I'm doing a senior design project for a company that will remain nameless. They produce a ground fault relay, and my task is to re-design it.
The GFR uses a zero sequence current transformer. I would like to learn as much as possible about these CT's. Can someone recommend good books or articles or websites that give a detailed explanation of these CT's?
Are there models of them in spice or other circuit sims? I would like to play around with simulations before I play around with real 1200amps, cough cough.
In my design im going to use ZC CT's that the company makes and use their output to control a micro-controller.
Thanks guys
Thanks guys
