zero reverse recovery diode
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Oct 24, 2015.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    pfc1.png what is the difference in wave form of Vds if D2 is zero reverse recovery and if has reverse recovery time.can some one please draw the wave form , and this effect on the ringing of the MOSFET ?.
  2. crutschow
    Mar 14, 2008
    13,509
    3,385
    Sounds like homework.
  3. TAKYMOUNIR
    Jun 23, 2008
    351
    this is not a homework , this something I need to understand it, so can you please show what is the different in current and voltage of vds in both cases
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    This appnote has a pretty good explanation. A zero reverse recovery time is a physical impossibility, and although it can be made very short it just cannot be zero.
    http://www.vishay.com/docs/84064/anphyexp.pdf
    The effect of the non-zero reverse recovery time is that the diode will conduct in the reverse direction for some period of time. The characteristic is non-linear so the result will be distorted.
  5. MrAl
    Distinguished Member
    Jun 17, 2014
    2,567
    521
    The capacitance causes some ringing so you'll see ringing even with a small capacitance.
    The recovery mechanism is considered to be a different phenomenon. The shorter the recovery time the shorter the reverse current pulse will be through the diode.
