I'm trying to figure out what I'm doing wrong here. When I have a cadmium sulfide photocell unconnected I can get a resistance reading across it. When I connect it to a voltage source, I'm not getting any resistance reading whatsoever, but I can measure a voltage drop across it that is variable with light, so I know its still working. I've set my multimeter from the 2K ohms setting all the way up to 2 mega ohms and I still get the "1 . " reading when its connected to any voltage source whatsoever. If I disconnect the voltage source, I can get a resistance reading again.
What gives? Does the photocell have some property that I don't understand?
