Zero current switch resonant buck converter
Discussion in 'Homework Help' started by Ahmad Itani, May 8, 2016.
  1. Ahmad Itani
    Apr 11, 2016
    10
    I'm designing a full wave ZCS buck converter with input 12V and output 5V with Pout=2W.
    My question how can the switching frequency (20kHz, 60kHz, ...)affect the output average voltage and affect the shape of the waveform? thank you
  2. DickCappels
    Aug 21, 2008
    2,753
    665
    Your question is fairly open-ended. Generally speaking, designing for a higher frequency puts more dependence on the speed of the active components and parasitic reactances.
  3. Ahmad Itani
    Apr 11, 2016
    10
  4. MrAl
    Distinguished Member
    Jun 17, 2014
    2,548
    512
    Theoretically the frequency doesnt affect the average the duty cycle does, but when the cycle time is comparable to the turn on or turn off time of the switching device then it can but only if it's in a feed forward type converter. With the right feedback though it's a different story, the duty cycle would be changed to compensate if needed by the error amplifier and associated circuitry.
    The shape of the waveform may change a little because of the LC natural resonance, but again with the right feedback a slightly curved output vs a straight line up and down would stll be compensated for.
    I would think you'd be more concerned with getting the zero current or voltage timing right, unless you got that already. There is a general form for the average though and that is the mean:
    (1/T)*integral f(t) dt
    over at least one period T.
    f(t) is determined from the circuit arrangement.
    I dont have that much experience with resonant buck converters but we can look around on the web for more information too.
