zero crossing switching in three phase systems
Discussion in 'General Electronics Chat' started by m121212, Sep 13, 2015.
  1. m121212
    Thread Starter Active Member
    Jul 24, 2011
    71
    In a single phase AC system, it would make sense to disconnect the load at a zero current crossing (and to activate it at a zero voltage crossing).
    What about in a three phase system? If one phase is at zero, the other two are not. Is one phase just selected to spare the switching element for that phase?)
    Are all phases switched simultaneously?
    If zero crossing switching is indeed useful for three phase fixed frequency systems, is it also useful for three phase variable frequency systems?
  2. GopherT
    Nov 23, 2012
    6,308
    4,029
    See page 8
    https://www.fairchildsemi.com/application-notes/AN/AN-3004.pdf
    m121212 and #12 like this.
  3. Lestraveled
    May 19, 2014
    1,957
    1,218
    Please note that zero crossing circuits only trigger the triac at zero volts. The triac itself turns off when the current drops below a threshold.
    Johann likes this.
  4. m121212
    Jul 24, 2011
    71
    Thanks for the comments.
    I guess if it's a heater or a motor, it doesn't matter if the phases are disconnected at different times.
    In figure 16 on that app note, why do the switches go on when the voltage is non-zero?
  5. Johann
    Nov 27, 2006
    190
    30
    Well, the circuit is under power (functional), therefore whenever any phase is not zero, its appropriate switch will turn on as the triac will be triggered after the zero transition. Remember, the 3 phases follow up at 120 degree intervals in time.
  6. m121212
    Jul 24, 2011
    71
    I thought the whole point was to trigger such that the triac gates on _exactly_ at the zero transition.
