What is the purpose of a Zero-crossing circuit in a TRIAC optoisolator?
praondevou, thank you for finding this. Boss says $1 more per unit isn't a big deal. Now I don't even have to know what the Igt of the TRIACs is!!! Will probably be going with this. Why on earth isn't this filed under TRIAC optoisolators on digikey...
Good to know for the future. Thanks!You're Dad's right. Igt Max is a limit where things burn up. You will not need to go to that limit.
Everything you said indicates that you are on the right track. You can trust your instincts on this one.
According to the datasheet of the triac he had chosen the maximum peak gate current was about 1.6A (destructive), I think (this was in his other thread). Then there was a parameter Vgt max and Igt max. It was not clear at what gate current the device would begin to trigger. The app note from this manufacturer I posted mentions to use the Igt from the datasheet, it doesn't say anything about minimum values.Igt Max is a limit where things burn up.
In this datasheet we have the information that is missing on the optoisolators with triac output: Minimum Trigger current is MAXIMUM 8mA.S108T01.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Duane Benson
