Zero-Crossing Detector
Discussion in 'General Electronics Chat' started by cheesemunger, Feb 15, 2009.
  1. cheesemunger
    Thread Starter Active Member
    Jan 25, 2009
    53
    I've been using http://www.andrewkilpatrick.org/blog/?page_id=445 and it says to convert an AC voltage to DC and then use a 4n25. But someone else says I can just use a H11AA1 straight away which would make sense. If that is true then that is gd:) but I don't have access to that , I have access to ILD620, is that fine?
  2. Ron H
    Apr 14, 2005
    7,050
    657
    ILD620 should work. Limit the peak input current to ±40mA or less.
  3. cheesemunger
    Jan 25, 2009
    53
    How do you suggest I do that?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    With a series resistor. Choose the value using Ohm's law: R=V/I.
  5. cheesemunger
    Jan 25, 2009
    53
    so voltage is 240v and current is 60MA which is 0.06A. 240/0.06=4k
    so.... I could use a 4.7K 1/2W resistor? Or do I need 2 resistors in parallel to dissipate heat better?
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  7. cheesemunger
    Jan 25, 2009
    53
    Do I really have to you a capacitor? Can't I just use resistors? If I have to use a capacitor, does it matter what value?
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    On the page I gave you is stated how to calculate the value.
    Greetings,
    Bertus
  9. cheesemunger
    Jan 25, 2009
    53
    Wait, I'm not sure where I got my 0.06A from? LOL Where should I be getting it from?
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Ron H has said to limit the current for the ILD620 to 40 mA.
    I think the 60 mA was from the original schemaitc.
    Greetings,
    Bertus
  11. cheesemunger
    Jan 25, 2009
    53
    On the website I posted to begin with he used 2x 47K 1/2W resistors in parallel, why can I not just use that?
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    It depends on how many current you want to have on the led.
    In the origenal with 2X 47K there will be ca. 10 mA on the led.
    Greetings,
    Bertus
  13. cheesemunger
    Jan 25, 2009
    53
    all its got to do it provide a high signal to a microprocessor (arduino) so 10mA should be fine.
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    It is the current in the led, not the transistor.
    Greetings,
    Bertus
  15. eblc1388
    Nov 28, 2008
    1,542
    102
    Using a capacitor to provide voltage drop is common in many applications but not in this case where the aim is to detect the zero crossing of the AC voltage.
    Adding a capacitor in the detection path will inevitable shiftes the zero crossing point from the true zero crossing and makes the detection invalid.
  16. cheesemunger
    Jan 25, 2009
    53
    eblc1388: Thats what I though :p
    If you look later on in his post at his final schematic, he removes the led and just connects it to an input pin on a microcontroller.
  17. eblc1388
    Nov 28, 2008
    1,542
    102
    Which post? :confused:
    Where can I see the final schematic? Can you provide a link?
    There has been a recent thread about feeding AC voltage into a PIC pin via high value resistor to detect zero crossing. Doing so has other problems too.
  18. cheesemunger
    Jan 25, 2009
    53
  19. eblc1388
    Nov 28, 2008
    1,542
    102
    I opened the pdf but still can't see what you meant. Sorry.:confused:
    Which input pin on the MCU are you referring to? Pin#22?
  20. cheesemunger
    Jan 25, 2009
    53
    look at Pin 21
