As apart of a circuit I am looking to make a comparator based zero crossing detector. I have a question about the correct input condition to the comparator which does not seem to be covered in my www searching.
The non inverting input has a sine wave signal with amplitude +5V to -5v. Can I use a rail to rail comparator (+5V to 0V) and would this require a diode to block most of the negative side of the signal? There are some rail to rail comparators which will go 0.7v below the negative supply.
While I can use a -5V supply rail I'd like to understand what can be used.
A
A
