Ok, I'm rectifying the voltage. But can you give me an algorithm to implement the zero crossing detector using PIC18F452??At the minimum, you will need to rectify the AC voltage. The A to D will be destroyed by a negative voltage. What is the magnitude of this voltage signal?
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Jake Hertz
