zero before decimal point
Discussion in 'Off-Topic' started by kubeek, Apr 13, 2014.
  1. kubeek
    Thread Starter AAC Fanatic!
    Sep 20, 2005
    4,686
    805
    can someone explain to me why the uk/us custom is to write numbers as .5 instead of 0.5?
    I would think that the decimal point in such notation is quite easy to miss, so a quick glance could mistake if for a 5.
    So is it beacause people were just lazy to add a redundant zero infront of the point, or is there some other thing that I am not aware of?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Maybe they expect users to not be lazy readers. My B&K Precision 'scope does not include a redundant, leading zero on any of the panel figures.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    Well maybe, but how about written text? I hope you can imagine just how easy it can be to mistake .5 for a 5, expecially with bad eyesight.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    I'd say you have a 0.5 chance of mistaking .5 for 5.
  5. kubeek
    Sep 20, 2005
    4,686
    805
    Exactly, so why not write it always as 0.5 or 5, so that the probability of error is much lower than 50/50?
  6. atferrari
    Jan 6, 2004
    2,663
    783
    Actually not an answer to your question; locally, people working in electronics name a cap like that as "point forty seven".
    In the lists that people bring when buying on the counter, it seems common practice to write the values as you say, .33 , .47, .68.
  7. djsfantasi
    Apr 11, 2010
    2,899
    870
    I personally teach or use in my writing, the use of the leading 0 where appropriate.
    However, I don't think it's lack of use is caused by laziness. It is more related to the fact that a leading zero is not used in other situations. Would you write 050 for fifty? Would you do so if you were summing five hundred to fifty ((500 + 50 ) = ? Or is it (500 + 050 ) = ?) In fact, from this point a case could be made that 0.5 is as confusing to the eye as .5
    Especially children in the earlier grades get confused enough by decimal points, without adding another 'special' case. Having said that, sometimes teaching a particular student to use or 'imagine' the leading zero aids in their understanding.
    :rolleyes: Disclaimer: I am not a certified teacher, but most of my family are. I have been in the classroom as a sub.
    Just my 2 cents.
  8. kubeek
    Sep 20, 2005
    4,686
    805
    I am aware of how it works nowadays, but I still can´t get to the bone of how it became that these two different notations emerged.
    My perosonal guess would be that it started as a difference between british and continental notation, but I don´t even know how would i google that to find something more. Any clues?
  9. kubeek
    Sep 20, 2005
    4,686
    805
    That is the point I saw somewhere when googling, and I don´t get it either. Why would you need to imagine a leading zero? It is just there and always has been.
    To me it is natural that 0.5 is somewhere between 0 and 1, and 1.3 is somewhere between 1 and 2. Now a .5 seems like a special case where the 0 is ommited just "because", while all other cases remain different.
    edit: could that be the reason why kids get confused with decimal points as you say?
    THE_RB likes this.
  10. djsfantasi
    Apr 11, 2010
    2,899
    870
    That is my point. To you what is natural, may be strange to others. I have seen frustrated people trying to understand why a number should EVER start with a zero. That numbers between 0 and 1 should be treated differently (from THEIR perspective) is confusing. Their perspective is that there are 'gazillions of numbers' and they just don't start with a zero. That is why I asked why couldn't someone write 050?
  11. kubeek
    Sep 20, 2005
    4,686
    805
    I would say that 1.2 is one plus a bit more, and 0.2 is zero plus a bit more.
    .2 being point plus a bit more just doesn´t seem right.
    Maybe it could be that the way they are taught doesn´t show zero as part of the system of numbers? Maybe if it were properly explained that 0.2 is zero ones and 2 tenths..
  12. djsfantasi
    Apr 11, 2010
    2,899
    870
    And what is "050"?
    Rhetorically speaking.
    By the way, I DO agree with you. Just think there is another perspective. No judgement on whether or not it is correct or incorrect, just that it exists.
  13. kubeek
    Sep 20, 2005
    4,686
    805
    To me 050 can only be the result when you are substracting 75 from 125, writing the numbers in rows. Otherwise it is missing the decimal point. - here you can see the advantage, it is much harder to lose a zero due to bad handwriting or poor eyesight, than to lose a decimal point and make 50 from .50
    I of course understand there is another perspective and that none can be called more correct than the other, my original point was more about trying to find out why did there come to be two standards, and what where the reasons for the difference.
  14. djsfantasi
    Apr 11, 2010
    2,899
    870
    Understood. Sorry about leading this thread away from your original question. Dj over and out :)
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't think it really matters.
    0.5 = .5
    It is a matter of personal preference.
  16. #12
    Nov 30, 2010
    16,655
    7,294
    I can testify that, clear back to the 1950's the leading zero was not taught in American schools. That doesn't say anything about, "why", only the fact that it has been accepted practice for nearly 60 years.
    I was a young nerd. I would have remembered. :D
  17. MaxHeadRoom
    Jul 18, 2013
    10,818
    2,494
    And 40% of the world uses (,) comma for decimal delimiter, the rest the Point (.).
    Max.
    #12 likes this.
  18. #12
    Nov 30, 2010
    16,655
    7,294
    Excellent (decimal) point Max. :D Customs vary across the planet. It was centuries ago that numbering and spelling conventions started. The, "why" of it may be lost in the mists of time.
  19. ronv
    Nov 12, 2008
    3,392
    1,447
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    Personally I use a leading zero to add clarity, but accepting there are other standards I don't obsess.
    I don't think I could handle $1,000,00 as $1,000.00. They have two different connotations.
