1. nayan kubasadgoudar
    Apr 20, 2010
    i have got a query.. can a 2v,600 mw zener diode be used for providing a 24v stabilizing supply to a variable load in any way?"??:confused:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome to the forums.
    We prefer you to start a new thread instead of hijacking an existing one.
    It does not sound like a 2 volt zener could do anything for stabilizing a 24 volt supply. You might use one with a divider circuit to provide an overvoltage signal. Can you give us more of an idea about how you were thinking of using it?
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    It could be used, as part of an overall voltage regulator, as the voltage reference.
    The 24V output would be divided by a resistor combination (so 24V in is 2V out) then compared to the zener voltage. The difference signal is used to control the main pass transistor.
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    This can work. Any reference voltage can work for this type of application with suitable amplification and feedback.
  5. lmartinez
    Mar 8, 2009
    224
    6
    Too broad of a question to make any assumptions....Please provide additional information...
